Ford EDIS Parts Wanted
Hi
I am looking for the following items:
Coil Pack
EDIS Module
Crank Position Sensor
Plug leads
Little grey box - read below
All of above perferably all from 1 vehicle with as much of the wiring intact(makes life easier). The need to be from the 1 of the following models:
1989-1993 Fiesta XR2i 1.6
1990-1992 Fiesta RS turbo
1989-1994 Escort 1.6i
1990-1994 Orion 1.6i
There should also be a small grey box near the coil pack, but I'm unsure of this. I heard this from another site saying percisely what it is:
I also need a 36-1 trigger wheel from a 1.8 CVH Sierra.
Thanks
Chris
Edit: (found a problem with not being a gold member! Can't post replies!) - I'm using it in place of a distributor with a Megajolt ECU, anybody know if I need the grey box?
Coil Pack
EDIS Module
Plug leads
Many Fords with EDIS systems also have a little greyish box with one wire connected to them near the coil pack. This will be the suppressor (capacitor) which eliminates electrical 'noise' - try to get this too, if you can - it helps the delicate circuitry in your ECU to operate reliably by protecting it from voltage spikes.
Thanks
Chris
Zoggon
Aug 10, 2015 10:39 AM
