Saff cossie bits.
Raid steering wheel for a saff.
£50 + post.
Set of clocks,white faced, 96k showing.
£25 + post.
Complete back end available too,Diff in very good condition and the rear beam and arms are fully polybushed, all discs and calipers included.
Saff electric roof ,all complete with button lights etc...even got the bit of panel which makes it really easy to fit on normal roofs.
£60 + post
Full Scorpion stainless exhaust system, 4 inch tail pipe....middle box is scrapped off the speed humps
and there is a hole in the down pipe for a lambda sensor,just needs a bolt in it to block up.
£75 pick up only.
£50 + post.
£25 + post.
£60 + post
and there is a hole in the down pipe for a lambda sensor,just needs a bolt in it to block up. £75 pick up only.
yes they are.
price been lowered too as there is a crack or two in the surrounds but cannt be seen when on,can be fixed easy enough.
lights are now £175 + post.
Originally Posted by nellyscossy
hi dave
got back to brum at bloody 11.30 last night
not bad just an 8 hr trip
that was one long trip out then.
normally only an hour or 2.
rsguy
44
Sep 29, 2015 03:29 PM
