mk 3 escort -
switch should usually be to the right of the steering wheel on dashboard, wont pass an mot without im afraid, chech behind where you see the 3 switches in the pic on you own dash and the wires/plug should be there, pick a switch up for a few quid off here or ebay
If it is a GERMAN SPEC right hand drive one and very early one it does not as standard have fog lights, my dads xr3 did not have them and was germna spec right hand drive in 1980.
The hole had a blank where the switch goes but all wires were there, and bulb holder just needed bulbs putting in and a small piece of wire joining the tracks together
Dr. Ickxs
Sep 15, 2015 10:15 PM
