cosworth rocker cover
Old Jan 8, 2007 | 04:09 PM
LukeT's Avatar
LukeT
Default cosworth rocker cover
hi all i have 2wd sapp with bailey group a breather system fitted, Im having some work done so i have bought a nice clean blue rocker cover to be fitted at same time but it is lacking the threaded whole to fit the top breaher pipe to, are there certain covers that have these wholes or do you have to have it machined yourself? Do i even have the correct cover? Please help
Old Jan 8, 2007 | 04:59 PM
righthooker's Avatar
righthooker
Needs to be drilled out ,if you turn over the cover you can see a nice circle on the underside
Old Jan 8, 2007 | 05:40 PM
xr_craig's Avatar
xr_craig
Needs to be drilled and tapped mate as said above
Old Jan 8, 2007 | 07:36 PM
SeanT's Avatar
SeanT
Wish my siblings would learn to spell
'Ite brav?
Old Jan 14, 2007 | 01:09 PM
MARCOSWORTH's Avatar
MARCOSWORTH
Look for the red circle,that's the drilling point
Old Jan 14, 2007 | 04:43 PM
SeanT's Avatar
SeanT
He's done it now (and very nice it looks too, shame it still leaks but that being sorted weds) - but thanks anyway marc
Old Jan 14, 2007 | 08:18 PM
PewteRS's Avatar
PewteRS
I got a couple of spare tubes to go in for a breather outlet if you need one
Old Jan 15, 2007 | 05:11 AM
MARCOSWORTH
btw it's Marco
Old Jan 15, 2007 | 05:43 PM
Evorich's Avatar
Evorich
thats where i drilled my hole
andyrs1600i
Aug 30, 2015 07:21 PM
bigryrs
Aug 29, 2015 10:51 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
