cossie spring rates
Old Jan 5, 2007 | 04:39 AM
graeme's Avatar
graeme
Default cossie spring rates
g day fellas
can any one help me with the spring rates of standard front &rear springs
and the same on koni springs on a 2wd saff
thanks graeme
Old Jan 5, 2007 | 08:17 AM
Mike1's Avatar
Mike1
Default Re: cossie spring rates
Originally Posted by graeme
g day fellas
thanks graeme
G'day cobber
These are supposedly the changes from 3-door to Sapphire 2wd made by Ford.
Spring rates went up from 106 to 118lb/in at the front and 263 to 286 lb/in at the back.
Damper rates were made softer in bump and stiffer in rebound.
ARB was increased to 16mm on back
Castor increased by over one degree
Camber made fractionally more negative
Kingpin inclination made slightly greater.
Front knuckles re-designed to lower the front roll centre from 144mm to 70mm
I haven't got any info on the Koni springs I'm sorry but someone like Mike R knows his potatoes on this - he will also tell you if what I've said is rubbish
Old Jan 5, 2007 | 09:30 AM
Mike1's Avatar
Mike1
g day fellas
can any one help me with the spring rates of koni springs on a 2wd saff
thanks graeme
Have you tried asking Koni direct if they can tell you in the absence of anyone else knowing?
Old Jan 6, 2007 | 10:48 AM
Mike1's Avatar
Mike1
Couldn't find anywhere that has the Koni spring rates - anyone else know?
Old Jan 6, 2007 | 12:26 PM
Mike1's Avatar
Mike1
Anyone know? Are they a progressive rate?
Old Jan 9, 2007 | 08:20 AM
Mike1's Avatar
Mike1
Did you ever find out about the Koni ones Graeme?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
cossie330
Sep 27, 2015 04:13 PM
