Oil leak at front of cam cover 4x4 Saff
Old Jan 5, 2007 | 12:40 AM
captiva's Avatar
captiva
Default Oil leak at front of cam cover 4x4 Saff
Any ideas, have tried cam cover plus half moon seals, camshaft seals are all OK what next?
Old Jan 5, 2007 | 10:59 AM
rabmc's Avatar
rabmc
Ive got same problem mate , but sure mines is the camshaft seals
Old Jan 5, 2007 | 07:33 PM
NUTTIN RILLA's Avatar
NUTTIN RILLA
As rab says mate, did you do all four or just the outside ones as i believe theres bigger ones on the inside, make sure its coming from the top as if its from below the timing belt can throw the oil round, hope you get it sorted, i f*cking hate oil leaks
Old Jan 5, 2007 | 07:36 PM
costina's Avatar
costina
Live long and prosper!!
Remove the front cam caps and seal between cap and head, this is most
common as people forget this
Old Jan 5, 2007 | 11:46 PM
rabmc's Avatar
rabmc
Well me a nuttin rilla changed my cam seals (outer) and you could clearly see especially on the left side seal that it was knackered
Replacd both while we wee there and hopefully ts cured , as there was oil everywhere ! A real sight after giving it some !
I honestly thought i had a 20mm hole somewhee pi$$ing oil
Hope you get it sorted matey
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
st220kyle
16
Aug 14, 2015 06:13 AM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
