FAO: Any Knowledgeable Car/Licensing People RE; Towing
Old Jan 4, 2007 | 03:33 PM
Chris S's Avatar
Chris S
Default FAO: Any Knowledgeable Car/Licensing People RE; Towing
I no if u passed your test after 1997 and u want to tow a decent sized trailer u have to take a test.
not a problem.
but what is it we 70% and kerb weights ect?
What does GVW Mean?? Gross Vehicle Weight??
What does GCW mean?? Gross Cerb Weight??
says these on vin tag.
GVW-1645 KG
GCW-2375KG
AXEL 1-785KG
AXEL 2-860KG
wanting to tow a trailer of couple hundred kilos and an 800kg car so upto a tonne and a bit???
Old Jan 4, 2007 | 03:58 PM
scottbrown's Avatar
scottbrown
Default Re: FAO: Any Knowledgeable Car/Licensing People RE; Towing
not a problem.
GVW-1645 KG
GCW-2375KG
AXEL 1-785KG
AXEL 2-860KG
as long as the car is capable and the total weight does not exceed 3.5 tonnes you can tow 750kg.
not sure on vin off top of my head.
the axel weights will be the amount of weight that can be loaded in total over each axel. ie you may have 800kg in car but if its all over xel 1 its over loaded, basically needs to be spread.
Old Jan 4, 2007 | 04:00 PM
scottbrown's Avatar
scottbrown
if you need to tow more than 750kg then you would need your B+E licence, although my understanding is that you cannot exceed 3.5tonnes total weight unless you go on to do a C1 licence, but for full weight up to 44tonnes you need you C and then C+E licence.
Old Jan 4, 2007 | 04:05 PM
charlie luciano's Avatar
charlie luciano
Default Licensing
www.DVLA.co.uk
Luciano
Old Jan 4, 2007 | 07:11 PM
focusv8's Avatar
focusv8
Gross Combination Weight,
Now called Gross Train weight.
The Max Permitted weight of the towing vehicle, it's load, the trailer and it's load.
mk3ste
Oct 17, 2021 10:09 AM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
rsguy
44
Sep 29, 2015 03:29 PM
Cos500
Sep 16, 2015 09:50 PM
