Right resistance for PF09 Throttle Position sensor at idle?
Hi all
I have recently changed over to L8 ecu, and I have changed the TPS over to the PF09. I have swapped the outer wires over, as requested, but I am having a little idle problem
Does anybody know what the resistance of the sensor should be when the throttle is closed?
thanks in advance!
JJ
thanks in advance!
JJ
Originally Posted by pondscum
Have you tried unplugging the ICV to make sure its not a vacuum leak?
JJ
Originally Posted by JjCoDeX75
PS - Welcome back Chip!
Sorry for bugging out early the other day - how did it go for the rest ?
JJ
JJ
I love how the photos in no way portray how short I was there for!!!! PMSL
Your car was easier to focus on that phils, so despite taking a couple of hundred of his and a couple of dozen of yours, I ended up with the same number of useable pictures of you both
And ive got twice as many of mine as EVERY picture that gets taken on the yellow car seems to come out perfectly
This whole picture needs lightening up a bit of course, but look at it for an example.
Focus point is the centre, me and phil are pretty much equal distance from it, my car is pretty much perfectly shown, his is just a murky blur
Its cause of the colour of his versus the background I think, it was a nightmare!
Came out fine when I took pics of it at castle coombe on a decent day though!
PMSL - My car is very photogenic!
I only realised afterwards that the 14" rims I have on my XR4X4 would have probably fit on the back of the cossie, and they have absolutely no grip at all! Oh well, know for next time.
The photos you took came out really well - as you say it is probably the colour of Phils car against the background!
I was well impressed with you little motor mate - first time I have seen it.
Rach was not having a great time, and I didnt want to push my luck given that I had already done damage (or so I thought!!!)
Good to meet the other guys (albeit quickly) - Hopefully my car will be an international superstar along with yours and phils in FF then!!!
JJ
JJ
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
