level 8 ecu
Old Dec 31, 2006 | 04:08 PM
MICKY84's Avatar
MICKY84
Default level 8 ecu
can i run the following using a L8 ECU?
water injection?
8x injectors? if so where can i get a loom
water spray?
coil pack conversion?
lambda controled fueling?
Old Dec 31, 2006 | 08:56 PM
Daxcossie's Avatar
Daxcossie
Default Re: level 8 ecu
water injection? / water spray? (You will need a Secs monitor still)
8x injectors? if so where can i get a loom (If you go for an MSD setup, you could run some large Siemens injectors to handle big bhp)
coil pack conversion? (Yes - MSD will need to mod)
(Yes)
Old Jan 1, 2007 | 11:32 AM
DazC's Avatar
DazC
water injection?
water spray?
I am pretty sure I am correct when I say this but it would be best to confirm with someone like Stu at MSD....
With the Pectel Super 8 conversion (8 injectors) the software cannot run closed loop fueling (lambda) as it is incapable of doing so.
If you want closed loop, you'll be better off sticking with 4 large injectors and having it mapped with closed loop on the Webber software already in the ECU. That way, you don't have the expense of the 8 injector set up (4 extra injectors, the manifold, the fuel rail, the regulator, the wiring, the ECU mods, the induction pipes (if using the RS500 set up), the throttle cable bracket). Obviously a different story if you're running an RS500 anyway.
You could always speak to Mike Rainbird about the RP Labs L8 modifications. This raises the spec of the L8 to beyond the Webber P8 Escort Cossie ECU.
Old Jan 1, 2007 | 07:15 PM
MICKY84's Avatar
MICKY84
cheers guys
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
griffo69
Oct 4, 2015 11:58 AM
IainRS1700T
Sep 25, 2015 06:44 AM
DixieTheKid
Sep 14, 2015 09:04 PM
