how do you make your pc run quicker...
Originally Posted by rob v
Originally Posted by c.h.r.i.s
Originally Posted by Davey C
http://www.ccleaner.com/
fucking hell
Originally Posted by Jim Galbally
yeah but filling up your HDD doesnt affect the speed, so you may have cleared off 1gb but you havent gained anything speedwise
porche, i couldnt disagree with you more there
the read/write performance of your HDD when it comes to non-sequential RW ops will be TERRIBLE compared to it's sequential performance. remember the the heads will be bouncing all over the disk trying to read all the little fragments, which takes time and slows performance.
say youve got a 5ms seek time, and your file is fragmented in 5 parts... thats an EXTRA 20ms to read that file than it would be if it wasnt fragmented!
the reason defragging is not so relevant nowadays, is that NTFS is SO much better at organising files, thet's it's quite rare to seriously fragment your HDD unless youre constantly copying/deleting stuff. plus the content that normally ends up getting fragmented (data files, like say movins, mp3s etc.)isn't so sensitive to data transfer througput
Originally Posted by Porsche911r101
lol people are so misinformed arent they.
hdd speed is the same say 7200rpm therefore where files are located on the hdd doesnt matter, so no point in defragmenting.
buy more ram
buy a faster cpu
etc.
buy more ram
buy a faster cpu
etc.
fragmented files take longer to find and load, imagine having to put a jigsaw together every time u wanted to load a file
Righto,
Defragmenting your hard drive does make some differance, startup items is the main software thing that can affect your pc. Click on start, click run, and type in msconfig. It will open the system configuration utility. Click on the startup tab, then, untick everything you feel you don't need to have running
Originally Posted by jameswrx
I just ditched norton antivirus and got NOD32 (which was reccomended) and it seems much happier.
Must say works a treat and guess what - PC doesnt hang and bog down like it used!! bonus all round.
Am going to try ccleaner now. thanks for the info.
The only file systems that do not require defraging are those which do not fragment such as ext2
Originally Posted by Escorton8's
Just delete all that porn off it mate .. it'l be much quicker
i want to give it a try
Indyrs
20
Sep 1, 2015 09:04 AM
