help
Old Dec 31, 2006 | 03:41 PM
justin j's Avatar
justin j
Default help
just found where water was leaking is it an easy fix what they called and get u get new 1s
where these go on 2
Old Dec 31, 2006 | 03:49 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
looks like the heater matrix
Old Dec 31, 2006 | 03:50 PM
rapidcossie's Avatar
rapidcossie
its the heater matrix as above...
nellyscossy's Avatar
nellyscossy
thats the heater matrix need to change it and to do that the dashboard has to come out...you should be able to get a second hand heater matrix easy enough
Old Dec 31, 2006 | 04:04 PM
justin j's Avatar
justin j
thanks for the replys is it a hard/big job
Old Dec 31, 2006 | 04:11 PM
Daveesaunders's Avatar
Daveesaunders
As above heater matrix, you'll need to remove the lower half of the dash along with all the heating ducts. Then you'll need to undo the two nuts holding the heater unit to the underside of the bulkhead. ONnce you've got that far you can then pull the unit out far enough to get the matrix out.
Old Dec 31, 2006 | 04:23 PM
justin j's Avatar
justin j
cheers guys, where can i get 1 from, think its been leaking 4 a while ive just been topping it up then went about 10miles or so today shopping and noticed there was no heat coming threw checked under bonnet and there was no water in the header tank just glad i wasnt to far from home
Old Jan 1, 2007 | 10:55 AM
nellyscossy
they are the same in any sierra
