spot the difference...
Old Dec 31, 2006 | 10:01 AM
Mr C's Avatar
Mr C
Default spot the difference...
Whats the difference between these two pics?
Im refering to the brakes and nothing in the back ground
and
Ok so its the bleed nipples on the calipers, while the 1st one is correct for bleeding the orientation on the caliper is incorrect, on the second pic the orientation is correct but the bleed nipples are the wrong way round.
The brakes have been fitted to a sapphire in the past so I should imagine they were fitted incorrectly??
The brakes are AP4pot CP5100 s, can anybody tell me what piston sizes are in there and any trouble with having run them the wrong way round, apart from poor performance or squealing? And should the anti rattle plate be at the top or bottom of the caliper, Ta?
Im just going to swap the link pipe for the nipples anyway
Old Dec 31, 2006 | 10:18 AM
filthyrichie's Avatar
filthyrichie
u wont get a decent pedal cos u cant get all the air out
Old Dec 31, 2006 | 10:23 AM
S1's Avatar
S1
I assume they have a custom bracket that goes between the caliper and the hub assembly. Is it not possible to remount the bracket so the calipers have the same orientation as in the second pic but are sitting in front of the disc, bleed nipple upwards?
Oh and get yerself a decent jack, how anyone works with those mickey-mouse jacks i'll never know
Old Dec 31, 2006 | 10:40 AM
GpA4x4's Avatar
GpA4x4
if pistons are same size just swap the crossover pipe and nipples around.
Fiddy
21
Sep 29, 2015 06:10 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
Vacuman
Sep 11, 2015 11:37 PM
cossiestu
Was It You?
Aug 2, 2015 02:49 PM
