ITS ALIVE!!!! Wahey!!!!
Old Dec 30, 2006 | 04:26 PM
BigErn's Avatar
BigErn
Default ITS ALIVE!!!! Wahey!!!!
After recent running problems and mental overfuelling, running on 3 cylinders and generally pissing me off. I started the car today and let it idle for 3 mins max. Looked down and spotted this.........
[img][/img]
The car was further forward when I started it and from what I can see it was coming from the exhaust join from down pipe to centre section. Not sure if its just condensation or not but it smells really strong of petrol and is really slippy when you step on it, plus its got a black sooty look to it too.
Am I worrying about nothing?
Old Dec 30, 2006 | 04:30 PM
MattyRST's Avatar
MattyRST
It doesnt look healthy mate
Old Dec 30, 2006 | 04:31 PM
MattyRST's Avatar
MattyRST
But i may be wrong
Old Dec 30, 2006 | 04:32 PM
Damo V's Avatar
Damo V
sump full of petrol???
Old Dec 30, 2006 | 04:41 PM
cozzymatt's Avatar
cozzymatt
looks like you got major over-fueling problems there mate..
Old Dec 30, 2006 | 04:50 PM
Kop2381's Avatar
Kop2381
It doesnt look too clever to me
Has it had any recent headwork ??
Old Dec 30, 2006 | 04:53 PM
pee vee's Avatar
pee vee
if it leaves a stain in the morning you know its not water!
to be honest though mate, that looks way too much to be just condensation in the exhaust
Old Dec 30, 2006 | 04:54 PM
Disabled Account's Avatar
Disabled Account
From the position of the fluid leak, I would say that the turbo OIL drain pipe has perished or come off the steel tube that go'es in to the block.
Old Dec 30, 2006 | 04:56 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Re: Is this bad??????
You got a ton of fuel smelling stuff pouring out the centre section of your exhaust, yes, id say you got plenty to worry about, and not just a blowing exhaust
Running on 3 and now its pouring out the exhaust sounds like one of the injectors has failed wide open and is just pumping for gold.
Injector, plugs, and oil change at very minimum (and fix the exhaust leak ), just hope you not washed the bore too badly, or damaged the rings or bearings because of all the fuel.
Hopefully not too bad.
Old Dec 30, 2006 | 05:04 PM
Disabled Account
See the little green arrows:
Old Dec 30, 2006 | 05:05 PM
BigErn's Avatar
BigErn
I was trying to stay positive and hoped it may be nothing to worry about.
Its injector 4 giving me gyp, I swapped 2 and 4 and its still number 4 missing. Had wiring checked and its ok, getting a lend of another ECU with stage 3 chip tommorow to try and eliminate that problem. Its not looking good for me, Im sure Im cursed against these cars.
Old Dec 30, 2006 | 05:06 PM
BigErn's Avatar
BigErn
Its definately not oil, its sooty water which reeks of petrol.
Old Dec 30, 2006 | 05:08 PM
smitsturbo's Avatar
smitsturbo
them green arrows are well hard to fix aswell
Old Dec 30, 2006 | 05:11 PM
Tarren's Avatar
Tarren
Hope your neighbours dont smoke or have a habit of flicking there fag out the window mate
hope you get it sorted fella
BigErn's Avatar
BigErn
Yeah I looked for one in my engine bay but couldnt find it. Do you think thats why its got running problems? Lol
Old Dec 30, 2006 | 05:14 PM
BigErn's Avatar
BigErn
The next door neighbours on both sides are cool, but the rest of the street hates me (My street is 1/2 mile long too and I live in the middle) so someone will prob try and set it on fire. They dont understand why I warm the car up at 7 in the morning before I drive it to work.
Old Dec 30, 2006 | 05:20 PM
Disabled Account
Can you have a look at your dip-stick? Check the level and condition of the oil.....
Tarren's Avatar
Tarren
I feel for you fella
Sod the fooking neighbours you crack on
Any ideas what it might be ??
Old Dec 30, 2006 | 06:02 PM
rabmc's Avatar
rabmc
Not get to a specialist at all ?
Soon as ? hope alls ok
Old Dec 30, 2006 | 07:13 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Just like Vin Diesel, you're living your life 1/4 mile at a time then....
Sorry..couldn't resist.
Hope you get your green arrow problem sorted at little cost
Old Dec 30, 2006 | 07:26 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
doesnt look good though to be honest and in my experience its never the cheap or easy scenario
Old Dec 31, 2006 | 12:03 AM
BigErn's Avatar
BigErn
These cars really dislike me, I had my last one all of 6 week before its head gasket went, so I thought. Changed that and still no better, so pulled the head off, which a presure test revealed a crack. Saved up for a while till I could afford another head, rebuilt it and again still no better. Full engine out and stripped, mostly in the kitchen (sorry mam). Pressure test on the block revealed a cracked cylinder liner, so the liner was replaced and the engine rebuilt using all ARP stuff. After running it in for 1000 miles I put my foot down and up shot the temp gauge. Bugger!!!! My guess is it had done another liner cos I only had 1 replaced. I got made an offer from a lad who was desperate for it, Ł3800 for a Cossie needing a block was good money to me so he got it. In total I had drove the car for 9 weeks max out of the 8 month I owned it. He had it 2 weeks and sold it on for a loss. The lad who got it after that put a head on it and found out it wasnt the problem so its current state is now bare shell in process of being made a big power show car.
Now Im having running problems and getting gyp off this one, Im definately cursed!!!
Old Dec 31, 2006 | 12:07 AM
danneth's Avatar
danneth
TORQUE!
your worrying about nothing
Old Dec 31, 2006 | 12:16 AM
BigErn's Avatar
BigErn
Thats what I thought, thanks mate.
Old Dec 31, 2006 | 12:20 AM
SS1's Avatar
SS1
said Saddam's lawyers
Old Dec 31, 2006 | 12:21 AM
BigErn's Avatar
BigErn
PMSL
Old Dec 31, 2006 | 10:28 AM
st3v3's Avatar
st3v3
Now im no expert, but when you say "do i have anything to worry about ?"
Im thinking....yes,im not sure why,but im getting vibes....
Old Dec 31, 2006 | 11:01 AM
Alan s1's Avatar
Alan s1
Take the injectors out and get them tested m8 that will tell you if 1 jammed open
Also the inside of your Exhaust should look nr concourse now
All the best Ps i have had my cossie 2yrs only used it for 6months well only tax'd it for 6months
Old Dec 31, 2006 | 11:05 AM
rapidcossie's Avatar
rapidcossie
time to get it on a trailer and take to an expert..
save time and money in the long run
Old Dec 31, 2006 | 11:53 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
u need to get it sorted "professionaly".....oh....happy new year fella
Old Dec 31, 2006 | 01:40 PM
BigErn's Avatar
BigErn
Time to pay a visit to Stu methinks. Gonna have to start saving pennies and bangin the overtime in, may even take the shift I was offered tonight. 8pm tonight till 7am tommorow at Ł17 an hour, dealing with drunken arse holes on new years in a rough (but fun) pub/saloon. Our lass will kill me cos I promised to take her out.
Old Dec 31, 2006 | 01:41 PM
BigErn's Avatar
BigErn
Cheers Pete, all the best to you and the family for 2007 mate. Take care.
Old Dec 31, 2006 | 06:22 PM
BigErn's Avatar
BigErn
Tried a differnt ECU and chip on it and still no difference. Next step is injectors out and sent to be tested. Anyone know where does it? Preferably in the north east.
Old Dec 31, 2006 | 06:37 PM
Alvyn's Avatar
Alvyn
have you done a comp test? if that is ok swap the injectors round to eliminate the one you think NOT working! if it's o/fuelling map sensor,coolant temp sensor, tps or fuel regulator are knackered!
Old Dec 31, 2006 | 11:46 PM
BigErn's Avatar
BigErn
Comp test ok, new coolant temp sensor, new crank sensor, peviously swapped injectors round and it made no difference, had injector wiring tested, checked TPS switch, MAP sensor 'looks' brand new. Fuel regulator been off the car but I dont know if they can be tested?
Old Jan 1, 2007 | 03:04 AM
mrviper's Avatar
mrviper
take turbo off and see if its before or after the turbo
Old Jan 1, 2007 | 03:29 AM
James's Avatar
James
so you've got fuel pumping out the exhaust?
you say it was missfiring on 4th so you swapped the injector with another cylinder and it was still missing on 4th?
what do the plugs look/smell like?
you sure the fuel is comming from the drivers side of the engine/exhaust?
you've not lost an injector seal somewhere have you?
Old Jan 1, 2007 | 06:43 AM
Jay,'s Avatar
Jay,
Sponsor
ern send the injectors to phil (bosch man) second to none service
Old Jan 1, 2007 | 11:46 AM
SapphyMike's Avatar
SapphyMike
neither can i, cos you dont need to leave your car running at 7am for any length of time.
that said, i do hope you get your problem sorted out
Old Jan 1, 2007 | 12:20 PM
toff's Avatar
toff
have you tried swapping injector connection.
