cossie pistons
Old Dec 30, 2006 | 04:06 PM
MICKY84's Avatar
MICKY84
Default cossie pistons
can some 1 please post picks of a 2wd piston, a 4x4 piston and a low compression piston please
Old Dec 30, 2006 | 05:32 PM
cossie604's Avatar
cossie604
sorry have no pics of pistons but, the way to tell between a 4x4 piston and a 2wd piston is that the 2wd gudgen pin in central where as the 4x4 pin is off set (very slightly tho so look carefully) to combat piston slap/rock. Also the 2wd compression bowl is larger than the 4x4's altho thats a pretty useless thing to know if you only have one type of piston and no other to compare with
Old Dec 30, 2006 | 06:36 PM
costina's Avatar
costina
Live long and prosper!!
2wd has a flat circle about the size of a 2 pence piece in the centre
if that helps
Old Dec 30, 2006 | 06:57 PM
cossie604's Avatar
cossie604
My bad...I do have some pics of pistons...here's mine from my engine build. ive used 4x4 pistons...
If you look at the top left piston in top picture you can see that the pin is very slight off centre.
Old Dec 30, 2006 | 10:06 PM
costina's Avatar
costina
Very artistic
Is there any markings on the top of your new pistons? like the orininals have??cos i've seen a few with nothing on them
Old Dec 30, 2006 | 10:09 PM
cossie604's Avatar
cossie604
lol thank you....can you tell i was bored one day with my box of parts?
Old Jan 1, 2007 | 06:29 AM
2001ode's Avatar
2001ode
Default Re: cossie pistons
Hi,
As follows, a view of 2 wd piston cut, and a view of 4 wd piston.
Regards.
Claude
Coupe de piston 4x2
Piston 4x4
Old Jan 1, 2007 | 07:17 PM
MICKY84's Avatar
MICKY84
cheers guys for your help
Old Jan 1, 2007 | 07:23 PM
costina's Avatar
costina
A 2wd one complete with valve cutouts
Old Jan 1, 2007 | 08:15 PM
cossie604's Avatar
cossie604
Those two pics show the visual difference when in block very well...2wd has the small centre compared with the larger centre in the compression bowl of the 4x4 piston crown.
You have the valve cut out machining done the very quick but costly way then costina??
Old Jan 1, 2007 | 10:26 PM
costina's Avatar
costina
LOL every 2wd engine i've see has been like this Pinto cam timing!!!!!
Old Jan 1, 2007 | 10:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mines not
You got a new head for yours yet Paul ?
Steve.
Old Jan 2, 2007 | 09:59 AM
costina's Avatar
costina
Mines not
Steve.
Yes Steve all sorted need some time now
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
