rear disc conv problem help!!!!
Old Dec 29, 2006 | 08:00 PM
stuartrst's Avatar
stuartrst
Default rear disc conv problem help!!!!
Hi i have recently done a rear disc conversion on my s2 erst using cosse 2wd disc and calippers all fitted up ok i have bled the hole system threw front and back but the brake pedal keeps going soft any ideas.
Old Dec 30, 2006 | 12:21 AM
jon@work's Avatar
jon@work
undo one of the rear caliper mounting bolts and twist the caliper round a bit to bleed them - when fitted on the bracket, the nipple is not the highest point but needs to be.
Old Dec 30, 2006 | 04:14 PM
sexr3i's Avatar
sexr3i
isn't it
as above, you still have air in the caliper above the bleed nipple.
Old Dec 30, 2006 | 06:07 PM
stuartrst's Avatar
stuartrst
wiil give that a go tomorrow then cheers for your help.
Old Dec 31, 2006 | 02:39 PM
stuartrst's Avatar
stuartrst
well done boys all done now perfect brakes give yourself a cigar.
Old Jan 1, 2007 | 05:50 PM
sexr3i's Avatar
sexr3i
isn't it
they'll get better the more you drive it, the rears take a while to bed in compared to the fronts.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
