COSWORTH GEARBOX T5 Q??????
Look similar but not the same box. Also diffo T5s dep on what TVR it comes from.
Depending what you want to fit it to they can be interchanged with a cossie T5 as they share the same box to bellhousing bolt config, but you need the matching parts. Ie prop/mount/bearing nose section.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
