going to look at a 3door what should i look for
Old Dec 28, 2006 | 03:33 PM
Tank Mike's Avatar
Tank Mike
Default going to look at a 3door what should i look for
its a rolling shell, but any tips on where to look for rust and anything nasty
Old Dec 28, 2006 | 03:35 PM
Ryan's Avatar
Ryan
front strut tops.
rear suspsension cups.
Dents on front wings inline with struts.
Cracks or split next to where the battery sits on the inner wing.
Chassis rails all round.
IF its a bare shell it should be pretty easy to spot anything.
obviously check its a geniune cossy if it is a cossy your looking at.
Old Dec 28, 2006 | 03:43 PM
Tank Mike's Avatar
Tank Mike
thanks mate, it is a cossie yes.
its got most things on it exsept from engine and box it think
Old Dec 28, 2006 | 03:53 PM
rabmc's Avatar
rabmc
Rear chasis rails , defo have a look there and all around where the rear beam sits
Old Dec 28, 2006 | 04:42 PM
Gav Diamond's Avatar
Gav Diamond
Rear arches if there is no kit on it
Under sunroof as sometimes the drains get blocked, but you will be able to get a good view if you open it
Old Dec 28, 2006 | 06:46 PM
col cos1's Avatar
col cos1
ive had 2 saphs,1 which the chassis leg was welded and it was such a good job it was hard to tell,the next were mint but patches on front floor,then 3 door,in which had sat off road in a drive for 5 years,and i couldnt believe how clean it was underneath,chassis legs solid,all it needed was a very small patch to 1 side of the boot in which u cant see from inside
pugo
Jan 14, 2006 04:37 PM
chriswrx
Nov 11, 2005 10:08 PM
Gaaables
14
Dec 29, 2004 06:21 PM
CozzyBrom
23
Oct 5, 2004 03:08 AM
CozzyBrom
Jul 14, 2004 06:05 AM
