cos headgasket change
Old Dec 27, 2006 | 04:24 PM
Basky's Avatar
Basky
Default cos headgasket change
the head gasket has,nt gone, im just freshening the engine
do you need to skim the head etc,or could you just swop the gaskets
going from grp a to a multilayer
Old Dec 27, 2006 | 04:30 PM
abdr500's Avatar
abdr500
Basky
yes you could give it a clean first to remove any trace off the old gasket but you realy need to make sure that both mating face need to be flat ..ther will be alot of peopl that will tell you you need the block and head skimed but i have on many time done with out but make sure they are flat
Old Dec 27, 2006 | 04:31 PM
ellicoss's Avatar
ellicoss
I would nothing worse than doing ll that work to find its no good its only about £40
Old Dec 27, 2006 | 06:33 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
That makes sense, but if he has little meat left on the head, or doesn't want to remove the block from the car then it's a little impractical.
I personally have done what Basky wants to do, and did it just like abdr500 has recommended. Good advice
However if there is any suspicion the head has warped it WILL need to be skimmed - best to check at the very least.
Si
Edited as I can't spell people's names!
Old Dec 27, 2006 | 06:37 PM
..for cometic multi layer type gaskets to work you HAVE to make sure both surfaces are completely FLAT.
Old Dec 27, 2006 | 06:42 PM
Basky's Avatar
Basky
Si
theres no sign of the head warped,as there is nothing wrong with it at the mo,its just that im freshening it up for this year,and also upgrading the gasket,ive a straight rule and feelers to check the surfaces,
Old Dec 27, 2006 | 06:47 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
every head gasket change i've always put a face on the head.....when i put my steel multi on the head was faced and the block was decked...everything flat as possible
Old Dec 27, 2006 | 09:47 PM
col cos1's Avatar
col cos1
il second that
Old Dec 27, 2006 | 10:17 PM
SapphyMike's Avatar
SapphyMike
il second that
thirded!
a metal gasket will find ALL imperfections in your head and block faces, and can ruin the head.
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
