2wd cossie spedo cable
Well i was removing bits so i can remove the box and engine and when i looked to remove the speedo cable (box end) its was just poped in no braket or any thing holding it is this right ?????
Originally Posted by Nath
I'm sure it had a collar with a bolt holding it in to the box...although I could be wrong as I'm not sure what you asked
That would make sence as theres a thead for a bolt to go in BUT theres no collar which holds it in to put the bolt in
dojj
28
Sep 11, 2015 10:00 PM
