Efi turbo conversion.
I have nearly all the parts you'd need to carry out an EFI turbo conversion:
OFAB ecu
OFAB engine loom
Edis module
Escort Cosworth 2.5bar map sensor
Modified 1800 cvh crankshaft pulley ( still with the 36 - 1 teeth! )
Modified 1800 cvh cranshaft sensor bracket and sensor
Modified 1800 cvh alternator bracket
1800 cvh alternator pulley
1800 cvh alternator belt
All you'll need is the easily sourced efi inlet with injectors, and the coil pack and you're away
£300.
Garyhayleyc@hotmail.com or preferably 07946 367994.
OFAB ecu
OFAB engine loom
Edis module
£300.
How much for...
Money waiting at right price
