Motorised kenwood KDC-W7031 MP3 Headunit.... (***SOLD***)
Not had this too long and it cost me a pretty penny!
Radio tuner features:
RDS (radio data system) & EON (extended other networks) tuner
Full coverage of LW / MW / FM wavebands with 24 presets (18FM, 6MW, 6LW)
Auto-memory entry feature stores preset stations
Display of radio text information
CD / MP3 / WMA / ACC features:
Compatible with CD, MP3, WMA and AAC format files
AAC compresses audio much more efficiently than the MP3 standard. Also used on the Apple iPod, Kenwood AAC compatible head units can reproduce files compressed using AAC-LC, including MPEG-4 and .m4a formats
CD-R and CD-R/W compatible
Display of CD text when present on media
Display of MP3 ID-3 tag information
Discs in optional CD changer can be manually assigned names
L/R 0-bit muting for total silence between tracks
Random track play, track repeat and intro scan functions
Amplifier features:
Four channel 4 x 50W max power amplifier (4 x 30W RMS)
Two stereo preamplifier RCA outputs (2.5 volt) for connecting optional external amplifier
Separate adjustments for bass, treble, balance and fader
Loudness control
System Q-EX equaliser with three control bands and six preset settings
System E's optionally cuts bass for front and rear speakers at an adjustable frequency, thus improving sound quality when a separate subwoofer is in use
Switchable, adjustable rear subwoofer output
Built in amplifier can be turned off if external amplification is used
BMS external amplifier control offers parametric EQ control of the Kenwood PS range of external amplifiers. You can also display amplifier status information such as voltage, current, temperature and fan speed on the GUI/OSD.
Dual-zone sound output facility
Source tone memory stores equaliser settings for each source (FM radio, AM radio & CD)
Other features:
Kenwood's unique 'G-Analyser' is an acceleration sensor built into the radio. Front and lateral G force readings can be continuously shown on the radio display, as well as linked to a displayed digital stopwatch to make vehicle performance timings
'Installer memory' switch will return unit to a preset optimum calibration, as programmed by owner or installer
64 colour x 8 shades (128 x 23) FL dot display with display blackout switch
Motorised removable front panel flips down to insert CD disc
Three step front panel angle adjustment
Automatic display brightness dimmer
Compatible with Kenwood CD disc changers
Compatible with Kenwood infra-red remote controls
Will accept auxiliary input cable for Walkman type device playback though radio
Compatible with Kenwood iPod interface to control, display information from and re-charge battery of Apple iPod
DAB reception can be added with accessory DAB tuner
Can be linked to many models of dashboard information displays and factory-fitted remote controls (requires accessory adaptor)
Rotary volume controller
Red or green (switchable) illuminated control buttons
Complete with release keys, ISO connecting loom, full fitting and operating guide
Security:
Removable front face with case
Security code protected
Covered by 12 month manufacturers warranty
i only ever listen to the radio and its powering standard speakers so it really is wasted, im gong to put the standard unit back in.
More specs can be seen here: http://www.incarvision.com/productdet.asp?Id=148
Looking for offers over £120
Amplifier features:
Loudness control
Other features:
Security:
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
