3 door steering question/help
Old Dec 23, 2006 | 12:11 PM
rabmc's Avatar
rabmc
Default 3 door steering question/help
As above people , basically failed my mot on a rubber bush(circular) , not sure the exact name of it , but its located on the rod that comes from through bulkhead and down towards steering rack , sits right in the centre of this rod , and realy need to know the name of it just so i can order up a new item , also i take it this comes apart you dont need to change this rod as a whole ?
Cant seem to get it of , theres strange looking bolts with a patern on them going throgh holding this circular rubber in place , but really dont know what to use to get it off
Any help appreciated
Old Dec 23, 2006 | 02:07 PM
cossie604's Avatar
cossie604
lol these are a git mate......they get too hot becuase of the turbo and they then harden and perish/crack up. Ford only sell the complete shaft..well used to, its proberbly no longer listed anyhows tbh. You also used to be able to buy a pattern part, which was a replacement rubber donut and a set of plates along with nuts and bolts. You have to grind off the old riveted plates and then bolt on the replacement. Take your shaft off and try a few motorfactors to see if they can still match it up. A few other people have had solid metal replacements made up insted...ment to give good feedback thru the wheel albeit a slightly buzzy wheel at times.
Stu.
Old Dec 23, 2006 | 02:30 PM
rabmc's Avatar
rabmc
My fookin luck mate
Nothings ever straightforward eh , may be better trying to get one from a breakers thats in better nick maybe
Thanks pal
Old Dec 23, 2006 | 02:44 PM
rabmc's Avatar
rabmc
Would this rod be different form the 2wd saff ?
Just incase
Old Dec 28, 2006 | 10:55 PM
Ian M's Avatar
Ian M
Just incase
its the same on a 2wd saphire, its called the steering coupling.
Old Dec 29, 2006 | 07:17 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
have a look around the brakers for an auto 1991 onwards sierra steering
coupling is adjustable in length
hope this helps
Old Dec 29, 2006 | 10:15 PM
rabmc's Avatar
rabmc
Thanks people , trying to source one at the moment , not easy at this time of year
Old Dec 30, 2006 | 07:45 PM
american's Avatar
american
baseball and apple pie
http://www.opmd.com/main.cfm?tpl=product.cfm&pid=9
[/img]
Old Dec 30, 2006 | 07:52 PM
johnny99's Avatar
johnny99
Are you not talking about the steering column bush that sits in the bulkhead and the column goes through it.
John
chowfornow
14
Jan 5, 2019 09:01 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Adam Graham
Sep 6, 2015 06:04 AM
