Next Upgrade?
Old Dec 21, 2006 | 03:41 PM
adam rs's Avatar
adam rs
Default Next Upgrade?
I have a 2wd saphire with the following spec-
Group A cylinder head
wire ringed 205 block
7.2:1 compression
t34 with .63 housing
lightened and balanced bottom end
BD14 inlet cam
rs 500 intercooler
30 psi
greys
L8 ecu
group A fuel pump
carl norris map
Although this set up has been ok for a while i feel it is time for a bit more.
I was thinking about fitting a ball bearing turbo and some 1000cc injectors.Anyone upgraded from similar spec and what can i expect power wise?Although the engine is fairly fresh i dont feel at the minute its any faster than my mates stage 3 4X4.
Old Dec 21, 2006 | 04:02 PM
adam rs's Avatar
adam rs
Sorry Wrong Forum!!!
tankybaby66
Feb 6, 2016 02:24 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sp3no
Sep 27, 2015 07:23 PM
focus2351
Sep 9, 2015 09:33 PM
