My Sapphire 4x4 track car
Here is my car i have been building for 16 months from a shell scs 410 bhp engine fix it gear kit more spec to follow[img
[url=http://www.avatarimage.net/imagehosting]
Engine 200 block 4x4 ported head scs cams low comp pistons full balance wrc head gasket big wing sump gray injectors garret t34 hybrid turbo 2wd exhaust manifold L8 ecu with pectal board pace rs500 intercooler pace rad mocol oil cooler with remote filter. Mapped by ahmad and harvy gibb to give 410bhp @6500 red line at 7100 torque 393.1 @3500 28 psi droping to 24 psi at the top.
Drive train fix it big tooth gear box nickel plated rear diff quaife atb front diff
Brakes and wheels Hi spec monster 6 pot fronts with 310 by 28 disc standard rear callipers black diamond discs peddal box operated, 16 inch by 7 with 25 off set team dynamics rv2 toyo proxis for wet, 16inch by 7 25 off set compomotive gp A wheels with michilan slicks for dry
Body seam welded 6 point safty devices cage full respray inside under side and exterior
jason_nike
Aug 18, 2019 10:53 AM
track.focus'd
Aug 12, 2015 05:53 PM
