how do you no
Old Dec 20, 2006 | 02:48 PM
SWIFTY's Avatar
SWIFTY
Default how do you no
how can you tell if your pisten rings need changein????
i have the head...
one thing i have done is filled the pots up with oil left it over night an the leavel stayed the same
Old Dec 20, 2006 | 05:09 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you get the workshop manual and read the bit about ring gaps and then measure yours and compare with the spec.
Old Dec 21, 2006 | 12:38 PM
dan5710's Avatar
dan5710
first of all look for blue smoke out the exhaust. filling the cylinder up with oil is good too, once you've got the head off. Also could try a compression test.
Old Dec 21, 2006 | 09:56 PM
bud-weis's Avatar
bud-weis
Football Cwazy
presuming your engine is still original and has never had a rebuild....look into the bore and about 10mm down you'll see a ring around the entire bore,if you can physically feel this ring with your finger nail then the chances are your bores are worn and therefore your piston ring gaps are too large,so they'll be allowing blow by and probably a bit of smoke
the only real way to know for sure is to remove the pistons,then take each ring off and place it into the bore,and measure the gap (should be between 0.4mm and 0.6mm i think but don't qoute me on that)
hope that helps
Old Dec 23, 2006 | 09:57 AM
SWIFTY's Avatar
SWIFTY
Default thank
thanks
