running lean
Old Dec 19, 2006 | 09:51 PM
kris k's Avatar
kris k
Default running lean
wats wrong if car running lean and how do u fix it
Old Dec 19, 2006 | 11:35 PM
Focus_RS1658's Avatar
Focus_RS1658
Maybe the fuel pump is on it's way out
Old Dec 20, 2006 | 07:45 PM
rssteve's Avatar
rssteve
you need to find the problem to fix it, get mroe fuel in.
Old Dec 20, 2006 | 10:22 PM
kris k's Avatar
kris k
wat more fuel goin to do
Old Dec 21, 2006 | 03:17 AM
Focus_RS1658
If the fuel pump has lost it's pressure or the injectors have blocked then a shortage of fuel can cause the leaness..
I'd get the injectors checked, fuel pump pressure and voltage test, could one or two of the oxygen sensors or a screwed MAF sensor..
If you get bluefin plug it in and see if there are any DTC fault codes
Old Dec 24, 2006 | 10:41 PM
kris k's Avatar
kris k
i have it says running lean
Old Dec 25, 2006 | 08:01 AM
Focus_RS1658
Got to be something wrong with either the fuel pump, injectors, oxygen sensors and MAF sensor then..
Try to avoid driving it and if you do have to use it keep cruise at 2000rpm to avoid coming on boost.
Where are you based?
Old Dec 25, 2006 | 09:25 AM
Wardy257's Avatar
Wardy257
If you have an induction kit/aftermarket filter my first guess will be the MAF. Give it a good spray inside with carb cleaner (engine off) and let it dry.
Old May 16, 2007 | 04:11 PM
LloydyRS's Avatar
LloydyRS
Whats MAF
Old May 16, 2007 | 04:54 PM
AlexRS2782's Avatar
AlexRS2782
Originally Posted by LloydyRS
Whats MAF
Mass Airflow Sensor
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
