Only one headlight flashes???
Right,
The lights on my RST have been playin up since I had it, got most of them sorted now (
by removing the bridged wires in the fuse box and putting the relays into the correct slots
) but one little problem remains.
When I flash the headlights only one flashes, and only one full beam (light switch on second setting, indicator stalk pushed back) works???
Any ideas?? Could anyone tell me which relay controls this light setting??
Lee
) but one little problem remains.When I flash the headlights only one flashes, and only one full beam (light switch on second setting, indicator stalk pushed back) works???
Lee
Originally Posted by SafeChav
Probably one of those relays you put in are faulty! Or a broken connection in the fuse box!
Cheers, I knew you'd be the first to reply SafeChav
Lee
Originally Posted by Moonie
Edit - didnt read it properly so my reply was a load of s**t
Keep up the good work mate!
I think It's relay #9, looking @ what Mr Haynes tells me. which is the right most relay on the second row from the top.
Could someone tell me the colour of the relay they have in this slot???
I'm expecting it to be a brown lighting relay, but the one I have is white.
Cheers,
Lee
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
Steve Escos
Oct 1, 2015 06:57 AM
