where is the best place to get a 2wd gearbox rebuild?
Old Dec 19, 2006 | 05:14 PM
kevin cozzer's Avatar
kevin cozzer
Default where is the best place to get a 2wd gearbox rebuild?
where is the best place to get a 2wd gearbox rebuild? or buy a good strong box? i live near oxford so the nearer the better really! cheers guys[/code]
Old Dec 19, 2006 | 07:50 PM
Sideways_Sierra's Avatar
Sideways_Sierra
Have a look through your yellow pages fella.
Old Dec 19, 2006 | 09:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can either have it done at cts (gearboxman off here- although i haven't seen him post for a while), or buy a rebuild kit from them (or many other places as the wc t5 is widely used in usa. rebuild is a relatively straightforward job - done mine myself
Old Dec 19, 2006 | 10:04 PM
Sideways_Sierra
How much/long did it take you ? Anything to look out for? Seen the gearbox rebuild kits on ebay myself, and wondered....
Old Dec 20, 2006 | 07:54 AM
foreigneRS's Avatar
foreigneRS
Testing the future
think the full rebuild kit (synchro rings etc + bearings) was about Ł200.
was done in a day. one difficult step in the whole process - removing 5th driven gear - as you need a very long puller to pull it off the output shaft and there is only a very narrow gap behind it.
if i was doing it again, i would strip it down to that point, take it to a specialist to have them remove it, then go back home and finish the rest. reassembly is easy, it's just the reverse of removal, and even 5th driven gear is easy to put back on with a piece of tubing the right diameter and a good press or fbh
Old Dec 20, 2006 | 06:59 PM
nice_head's Avatar
nice_head
Engine advantages rebuild mine for Ł200 on me old saff..
Old Dec 20, 2006 | 09:48 PM
Sideways_Sierra
Nick, cheers for that
Any special tools, apart from a go-go-gadget-puller ??
Old Dec 26, 2006 | 09:25 PM
2wd's Avatar
2wd
have talk to the guys in USA (5speed.com I think it was) ... I was told that the trick is to drop the counter gear axle down as far as possible, then it should be possible to cut the "bearing thing" on the inside behind the 5th gear wheel with at small "grinder"....then it should be possible to get the axle out and then pull off the 5th gear wheel....I cant remember the discription exactly, but it worked fine and we saved the 5th gear wheel.
if I remember tomorrow, I will find the mail I got from them, and post it here...
foreigneRS : what about the end float on both axels....did you check it yourself .. ? as I think about fixing another box myself (only took the first apart )
Old Dec 30, 2006 | 07:35 PM
foreigneRS's Avatar
foreigneRS
Testing the future
Sideways_Sierra only the puller really - plus a selection of tubes or whatever to press new bearings on
2wd yes, checked end float with a dial gauge
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
CLIVE
Oct 2, 2015 12:58 PM
cossiedean84
37
Sep 2, 2015 10:19 PM
FlashRS
13
Aug 31, 2015 06:02 PM
RIB1122
Aug 3, 2015 09:20 AM
