adjustable suspension
Old Dec 15, 2006 | 02:01 AM
kurdt5's Avatar
kurdt5
Default adjustable suspension
My s1 has adjustable suspension front and back but the owner i brought the car from has the back higher than the front, feels naff.
i want to jack the car up and reset the suspension.
Whats the best amount of turns front and back with the koni key to get a good all round ride hight?
how many turns for 25mm or 30mm all round?
Old Dec 15, 2006 | 02:11 AM
Andy_R's Avatar
Andy_R
Unless the Konis have been modified then the plactic key only adjusts the damping rate not the height.
Height is normaly adjusted by changing the springs. If your konis have been modified then the spring platform will be adjustable.
Old Dec 15, 2006 | 02:32 AM
kurdt5's Avatar
kurdt5
aaah....so if i buy some 25mm springs that should sort me out?
Old Dec 15, 2006 | 03:14 AM
Andy_R's Avatar
Andy_R
Yup thats the route i'd go down in your position, -25mm is spot on I wouldnt go any lower than that though.
Old Dec 15, 2006 | 07:10 AM
Marc LJX's Avatar
Marc LJX
Eibach springs are quite good
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
