any tip for removing old bushes ??
Old Dec 12, 2006 | 11:28 PM
bluescortcossie's Avatar
bluescortcossie
Default any tip for removing old bushes ??
as above really , as if removing 23 year old nuts isn't problematic enough i am having trouble removing some bushes , Ive tried the hacksaw and threaded bar but they wont budge
Old Dec 12, 2006 | 11:32 PM
xr4x4rs's Avatar
xr4x4rs
i usually burn them out
havnt tried any other way tbh, as im sure there quite well bonded in now, though some are pressed in anyhow so a hacksaw wnt do the job
if you do decide to burn them out make sure its ventiallated as rubber is horrible when lit
what car and what bushes aswell
Old Dec 13, 2006 | 12:10 AM
bluescortcossie
do you just use a normal blow torch or anything with some more grunt and its on my 3i and original bushes
Old Dec 13, 2006 | 12:22 AM
ben_frst's Avatar
ben_frst
just a blow torch and a big hammer
when you do finally knock it out just watch where your hitting it, into a pile for oily rags is not a good idea
Old Dec 13, 2006 | 12:30 AM
xr4x4rs's Avatar
xr4x4rs
yeah blow torch should be fine
i use oxy acetleyne does the job much quicker
Old Dec 13, 2006 | 03:09 AM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
I normally just stick them in the press, its a 150 ton press but i've never seen the pressure gauge go over 5 tonnes when pressing bushes or bearings. Even if I have to remove the suspension arm (or whatever) completely it normally works out quicker than fooking trying to remove it while its on the car.
Old Dec 13, 2006 | 05:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
can you get the part off teh car?
if so it's going to be a lot easier to get it to somewhere you can get it pressed out
failing that, jigsaw time
Old Dec 13, 2006 | 12:03 PM
bluescortcossie
blow torch worked a treat apart from it being too windy to do it outside so had to do it in my garage with the door shut , cant breathe now !
Old Dec 13, 2006 | 04:16 PM
xr4x4rs's Avatar
xr4x4rs
yeah not nice is it
i done the mistake of that to every bush on my sieraa
was fine when doing it as i didnt really see the smoke due to the flame
and wanted to get them out so i could get it all powder coated nxt day
stood up after and couldnt see the inside of my garage
i was fairly ill the nxt day
Old Dec 13, 2006 | 04:31 PM
lead_foot's Avatar
lead_foot
is awesome
Its alright getting them out but its a pain in the arse getting the new ones in there.
Old Dec 13, 2006 | 04:48 PM
xr4x4rs's Avatar
xr4x4rs
unless there being replaced with poly ones as most are 2 piece bushes
Old Dec 13, 2006 | 05:03 PM
bluescortcossie
i replacing them with polys so hopefully it wont be a problem , if they ever turn up that is ................. deflex
also i opted for hammerite paint instead of powder coat to keep costs down , wonder how long it will last !
DavidK
Sep 27, 2015 02:55 PM
