Another EFI qusetion but its an easy one
Old Dec 12, 2006 | 09:14 PM
marky_g's Avatar
marky_g
Fleet Manager
Default Another EFI qusetion but its an easy one
right gonna build an efi cvh from parts i have spare
i have an efi xr3i
i simply wanna know if i can use the head from the xr3i engine on the bottom end of an rs turbo mfi item
are the any differences in the xr and rs heads or iare EFI heads all the same?????
i had herd somewhere that to convert to efi u can use xr2i parts e.g head and inlet
Old Dec 12, 2006 | 09:18 PM
gee1599's Avatar
gee1599
the inlet ports on the efi head is diffrent to the rst thats ehy you need a head or a plate so answer to your question is yes you can use them
Old Dec 12, 2006 | 09:23 PM
marky_g's Avatar
marky_g
Fleet Manager
ok i basicaly just wanna know if i can put a rs turbo bottom end on an xr3i efi top end
so the head will all line up to the bottom end
loom hean and inlet are all there already as i have complete car (my daily)
Old Dec 12, 2006 | 09:27 PM
gee1599's Avatar
gee1599
yes efi top end fits stright on the rst bottom end the only thing the bottom end wont have is the hole for the cps sensor (unless its a fiesta rst bottom end)
Old Dec 12, 2006 | 09:30 PM
marky_g's Avatar
marky_g
Fleet Manager
cps semsor hole whats this can i make one????
Old Dec 12, 2006 | 09:50 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
yea the head fits however the port shapes are different between the EFI and MFI and because of this you require an adaptor plate you can get these from oddkiddcreations.co.uk
Old Dec 12, 2006 | 10:01 PM
marky_g's Avatar
marky_g
Fleet Manager
right the head is toatal complete wiith the efi manifold on it its a complete efi top end can find the plate u mean on his site think i better have a word with him wanna go cossie managment anyway
Old Dec 15, 2006 | 04:05 PM
steven botes's Avatar
steven botes
i have modded the standard head to accept the efi inlet , you simply mark out the non efi head with a gasket cut from the inlet manifold.
you do not need to open the head fully to the shape of the inlet manifold , you could probably be 1mm inside from the top the gasket without any problem
my uk import xr3i s2 has been running with this for a couple of months without a problem
efi head now to be fitted to my gotech t34 xr3
Old Dec 15, 2006 | 05:13 PM
SafeChav's Avatar
SafeChav
Personally, IMO, thats not a good way to do it, the gasket will be very weak and you run a high risk of blowing the inlet gasket out!
Old Dec 15, 2006 | 05:49 PM
marky_g's Avatar
marky_g
Fleet Manager
the head is not a problem i have a complete EFI Top end
but what whppens when people do the efi conversion on mfi cars never herd of anyone drilling holes
Old Dec 15, 2006 | 05:51 PM
SafeChav's Avatar
SafeChav
If your using an MFI block you will have to either drill a hole for the CPS, or use a trigger wheel on the alternator pulley.
Or, you can use the EFI block and drill the oil return cos its a N/A block
Or just get a FRST bottom end.
Those are your options
Old Dec 15, 2006 | 05:55 PM
marky_g's Avatar
marky_g
Fleet Manager
trigger wheel it is by the sound of things swapping pistons between from a 30k to 150k engine dont float my boat,
gonna go see jano as i gotta get parstand he only round te corner
but safechav thanks for ur help mate u def no ur stuff and i always hope to hear ur advice when i post a qusetion up u talk sence unlike other poeple
Mark RS
Oct 12, 2015 06:01 AM
jc1989rs
Sep 18, 2015 07:05 PM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
