Focus ST 5Cyl Turbo Engine Transplant
Old Dec 12, 2006 | 08:51 PM
BarryA's Avatar
BarryA
Default Focus ST 5Cyl Turbo Engine Transplant
I have the offer of a CatB 2006 Focus ST. I am thinking of using the engine for a project probably RWD has anybody any knowledge of a suitable gearbox which could be used and has any body any idea if the ford ecu could be used of if I would need to use an aftermarket one Motec seems to be good?
Any body transplanted this engine into anything?
Any info greatly received
Thanks
Old Dec 12, 2006 | 09:39 PM
AustenW's Avatar
AustenW
Hi Barry
Motec is the best but expensive
Definately the route to go
Old Dec 13, 2006 | 04:44 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
ooo imagine sticking it into a escort cossie or even a fiesta
need a new pair of underwear everytime u came home
Old Dec 13, 2006 | 07:16 PM
BarryA's Avatar
BarryA
Waiting to hearback from an omex dealer and spoke with Elite today thay have a six speed squential gearbox which will fit
Old Dec 13, 2006 | 07:27 PM
AustenW's Avatar
AustenW
Mr Ashcroft
Definately go with an aftermarket ECU, it will make life alot easier in the long term. You can then remove all the extra pipes for recirc etc.
I would use Motec when I do it again, proper ecu and good software
Elite are OK but Paul Jones sequential box has broke 4 times now
Which model are you looking at?
Still think you should buy the Volvo 270R motor. It's tweeked from the factory and you can get more out of them in standard form.
Probably cheaper too
Old Dec 13, 2006 | 07:40 PM
BarryA's Avatar
BarryA
Paul's box is ok now but I would go for the next model up the IL300 will also speak to quaife (got a number and a name to speak to)
Motec sounds good but bugger me it's expensive 1700+vat just for the brain
I know what your saying with the volvo motor but they are old and high millage where as the focus motor is brandnew and looks lovely striaght out of the box and remember I am nt looking for monster horspower this time 280bhp will suit me perfect
Old Dec 13, 2006 | 07:44 PM
AustenW's Avatar
AustenW
You'll soon get bored of 280bhp
Old Dec 13, 2006 | 08:00 PM
BarryA's Avatar
BarryA
Maybe! I can then allways get you to build me a vlovo motor.
Joking asside I want a car this time I can use all the power and go sprinting and do track days and thrash it round the ring.
Old Dec 13, 2006 | 08:38 PM
AustenW's Avatar
AustenW
The good thing about a turbo engine over your huge V8 is that you can select whatever power you want using a good boost controller at the flick of a switch
150bhp for when your misses is driving and then 300bhp for track use
I run mine on 10psi for everyday driving and 25psi for strip use
Old Dec 13, 2006 | 08:47 PM
BarryA's Avatar
BarryA
Good idea never thought of that I take it the motec will do that?
Do you think Lou will be able to cope with the gearbox?
Old Dec 13, 2006 | 08:55 PM
AustenW's Avatar
AustenW
Gearbox is quite easy to use after about 10 mins practice
Motec can do boost control according to gear too it also has traction control
You can always use a boost controller like a a turbosmart e boost 2 and adjust it manually via buttons.
I have my buttons mounted to my steering wheel now to select up and down if I feel the need to give it a bit more beans suddenly
Definately go sequential, you will not look back
A mild tuned 5cyl will see 300bhp for starters and will have loads of torque.
Great for a car that will weigh circa 550kg
Old Dec 14, 2006 | 10:16 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Hi Barry - nice to see you signed up here. Sounds like you've got some great plans in the pipe-line.
Old Dec 14, 2006 | 10:29 PM
bigandy's Avatar
bigandy
Hey, I was thinking of doing this as a nice conversion for my mk6 escort gti. Do you know if theres any cheaper alternatives to the gearbox? 6 speed sequential seems a bit OTT for what i'd want?
Andy
Old Dec 14, 2006 | 10:38 PM
BarryA's Avatar
BarryA
Andy if your fitting in an escort use the standard ST 6sp box as it's still front wheel drive (or is it a rwd conversion).I'm going elite sequential as I want it rearwheel drive.
Just be aware the ecu situations is going to be very expensive as nobody has done this before and getting the vvt to work will be a knightmare
Hi AGAR have we meet?
Andy looked at your mini build thread looks very god any updates as nothing since sept would love to see the finished job
Old Dec 15, 2006 | 06:05 PM
bigandy's Avatar
bigandy
Yeah, im thinking rear wheel drive same as you. My brother has a t5 that he's just killed the engine in, so i could rip out the complete loom ecu, lock barrell, clocks, everything
No real progress on the mini, been away at uni the last 3 months, just got back so might get round to looking at it over the next few weeks. I'll update my build post on here when theres something to talk about
Old Dec 15, 2006 | 07:33 PM
Mr Sam's Avatar
Mr Sam
you'll need a manual volvo 960 then you get the M90 gear box (good for 400bhp) kee the 960 engine i think you need the sump off that
Old Dec 15, 2006 | 10:44 PM
AGAR-COSWORTH
Redumbdancy
I was the person on Pistonheads who emailed you that info reciently
Old Dec 16, 2006 | 12:24 AM
BarryA's Avatar
BarryA
Old Dec 16, 2006 | 01:13 PM
RichieST's Avatar
RichieST
jesus, 15 bhp is enough for my missus
Old Dec 16, 2006 | 01:28 PM
marky_g's Avatar
marky_g
Fleet Manager
my missus cant even drive my rs is running 180 and she thought it would be faster.....nutter
PUT IT IN A MK1 ESCORT
or an mk4 escort, imagen opending the bonnet it see that looking up at u
or go 4wd like that bonkers BSR focia in PF this month
Old Dec 16, 2006 | 04:03 PM
T4KAF's Avatar
T4KAF
ive already got this engine . . .sounds sweet as fuck modd,d tho!!!
Old Dec 18, 2006 | 12:28 AM
BarryA's Avatar
BarryA
Mk1 Escort I like your thinking
Old Dec 18, 2006 | 02:50 PM
Black_RS's Avatar
Black_RS
Andy
Get the Mini finished 1st! Just been looking at your thread and thats very, very impressive! - especially as its all home grown! [/thread hi-jack]
Old Dec 18, 2006 | 04:01 PM
Mr Sam's Avatar
Mr Sam
http://retrorides.proboards86.com/in...ead=1148119858
volvo 5 pot turbo into the back end of a beetle
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
