collinite 476s double coat wax
Old Dec 12, 2006 | 02:07 PM
oilcosworth's Avatar
oilcosworth
Default collinite 476s double coat wax
Has anyone tryed this
would like to no as mite try it thanks neale....
Old Dec 12, 2006 | 11:14 PM
Gaz7's Avatar
Gaz7
Hi mate, #476s is really popular, especially this time of year, due to it's fantastic durability. It'll bead any water that touches your car like crazy, and gives a clean, bright finish.
For a deeper finish, you can use #915, which is Collinite's range topping wax. It's more expensive, but it's a great wax, and comes in a huge tin.
Gareth
Old Dec 12, 2006 | 11:29 PM
Gaz7's Avatar
Gaz7
#915 in action:
Gareth
Old Dec 13, 2006 | 12:11 AM
Alex Creasey's Avatar
Alex Creasey
As Gaz says, the 915 is classed as the top of the range but, the majority go for the 476s as theres so little difference between the two (the 915 has a slightly higher carnauba content).
Both will genuinely give a good 4 months of protection, if not more.
Old Dec 13, 2006 | 05:47 AM
oilcosworth
thanks for that, think ill give #915 a go then
cheeRS
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
Adam Graham
Sep 6, 2015 06:04 AM
