breacking 3 door lotts of bits and chrome bling updated
my own car that i crashed last year lotts of bits but shell and body kit are destroyed i also have the engine its a 2wd 200 block low comp bd14s vernier pulleys chrome inlet and rocker cover fully rebuilt with all new bearings and gaskets and all commetic gaskets it has done less than 2000 miles since rebuild
i allso have a set of mint rear quater window trims forgot to mention i allso have a brand new shell still in primer so if any one needs out give me a ring on 07757722264 it olso has some bling bitschrome rocker cover chrome inlet fuel rail and throtle body , stainles steel heat sheild, chrome altenator and bracket, brake resavor cover and cap, stainless oil filler cap stainles dip stick all the water pipes from the t34 turbo are chrome,chrome swirl pot .stainles grill brackets .stainles light brackets chrome bonet catch that sits in front panel ,stainles bonet stay .stainles radiator bottom hose , stainles lobster back pipe for both turbo top hose and inlet with dv take off stainless brackets for map sensor and egnition amplifior,fuse box cover, strut tops, ill give prices on what ever your after it olso has full set of samcvo,s and a l1 ecu and chip for grays
jacko need a few bits from the shell if you've got them?
bulkhead sound deadening in engine bay.
enire car sound deadening.
and carpet if its mint.
also need the brake lines which go across the back of the bulkhead
Alright mate
Im after all the arch liners with the clips.
Also after some door handles (interior) and plastics that run inside the doors (wire cover/kick plate???????)
Also indicator stalk as i know Marco needs one
Incase you missed it mate
Originally Posted by R4N S S
Jacko, have you got hte spacer thing that bolts on the rear qtr for the rear seat belt?
hi mate...sorry to see your car like that
im intrested in all the bling that is untouched...especially the cam cover and oil separator with both braided hoses and complete fitting?
cheers mate
cheers mate
Originally Posted by Dicko&Sarah
yeah he did and without a fookin mark on him sure he has 9 lives lol how many you got left now jacko?
TOP BLOKE CAR IS IN A SORRY MESS
