i got a rs turbo and had a slight, slight leak, the water level took a week to empty, so i bought some radweld and put it in, it stopped the leak, flushed the rad and engine out a week later, and its still sealed 6months on and not leaked a bit of water and the temps dont reach half way..
but i still agree with a repair job but then again, i tested it, it worked and now im been a tight twat!!
You could try 'leakfix' from Chemical metal/which is exactly the same as chemical metal/cheap as chips and will last forever/the rest of the rad will
of course rot but if 'yu's got no dough' for what's coming up in a couple weeks it'll see you through.
Good Luck
