Some cylinder head questions?
Old Dec 7, 2006 | 08:14 PM
cosrep's Avatar
cosrep
Default Some cylinder head questions?
Is it true that cossie YB exhaust valves are sodium filled and if so what advantage does this offer?
Whats the difference between standard valve guides and the bronze versions?
Old Dec 8, 2006 | 08:30 AM
J9BBY's Avatar
J9BBY
I've read somewhere that they are sodium filled. Supposed to aid heat dissipation or something.
Old Dec 8, 2006 | 12:14 PM
2001ode's Avatar
2001ode
Default Re: Some cylinder head questions?
Hi,
Exhaust YB valves are sodium filled to help heat transfert between valve head and stem. Because sodium is a metal, and is liquid state when engine is running.
In same idea, bronze valve guide is better for stem slipping, and is better to transfer heat between stem valve and head case.
Regards.
Claude
Old Dec 8, 2006 | 12:36 PM
sailorbob's Avatar
sailorbob
Early Cosworths had a bronze type alloy for the guides and later ones has cast iron (cheaper and longer lasting). Nover use pure bronze guides as they wear away very rapidly.
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
focus2351
Sep 9, 2015 09:33 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
cossirob
Sep 3, 2015 09:17 PM
