warped hub
Old Dec 7, 2006 | 08:00 PM
craig rst's Avatar
craig rst
Default warped hub
i have an escort rst s2 and it as got a warped front hub.do i get the hub skimmed or get a hub and carrier of a scrap yard.or get a new hub (this option is a little expensive)please help as i am on a tight buget the bearing feel tight.and it as warped 2 sets of disc in 6 months
Old Dec 7, 2006 | 08:25 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
its more likerly the bearing is duff and putting it off square but you wont bend the actual hub casting so worse case get another carrier (round bit) i have a few if you get stuck, fit a new bearing while its apart
Old Dec 7, 2006 | 08:51 PM
NUTS RuS's Avatar
NUTS RuS
Welcome to Pf
My advice would be not to skim the hub but replace it.
Is it warping discs only on this side as there are a number of things that could do that....
Tony
Old Dec 7, 2006 | 09:14 PM
craig rst's Avatar
craig rst
yes just this side.i put the car on axel stands and started the car put it in gear and the wheel was wobbling the other side was ok. took the wheel off and you could see the disc wobbling.sorry if this is confusing.
Old Dec 7, 2006 | 09:28 PM
NUTS RuS's Avatar
NUTS RuS
Have you tried replacing the bearing ?
Thats a cheaper option first
If when you have it on stands and you grab the wheel at 12 o clock and 6 oclock position, can you rock it about ?
Old Dec 7, 2006 | 09:38 PM
craig rst's Avatar
craig rst
have not tried the bearing.when i grab the wheel at 12,6 oclock its solid as a rock
Old Dec 7, 2006 | 09:47 PM
NUTS RuS's Avatar
NUTS RuS
wont be the bearing then.
Are the TCA bushes ok ? Same for the steering arm ? (track rod end)
Next would be to check for excessive play in the driveshaft (this being my guess as to the problem)
What disc / pad combo are you running ?
Im going through a number of things first as its uncommon for a hub to warp, although not impossible.
Old Dec 14, 2006 | 08:50 PM
craig rst's Avatar
craig rst
how do i check the drive shafts or do you mean cv joint
Old Dec 14, 2006 | 09:03 PM
NUTS RuS's Avatar
NUTS RuS
CV joint will do
Say that to some and they scratch their head
Old Dec 16, 2006 | 10:53 AM
craig rst's Avatar
craig rst
inner or outer
Old Dec 16, 2006 | 11:17 AM
NUTS RuS's Avatar
NUTS RuS
usually outer
Old Dec 29, 2006 | 10:16 AM
craig rst's Avatar
craig rst
ive changed the outer cv joint and the hub and bearing and its still doing it do you think it is the inner cv joint or drive shaft(small one)
Sierrasideways
Oct 8, 2015 06:37 PM
fordrallycar
Sep 30, 2015 07:57 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
jc1989rs
Sep 5, 2015 08:09 PM
