B&M short shifters(Thanks to christian@ATP)
B&M have just hiked their prices. I have amended my prices in the traders section and I'm afraid that's it in terms of UK supply.
We are actually making less profit at the current price than we were at any of the old prices.
Originally Posted by turboboss
does anyone sell them for the mk3 fiesta i would of thought its the same as the mk4 escort kit
Originally Posted by NIMRODS_RST
cheers guys
christian looks like u will be getting a call soon for me to place an order
just get xmas out the way
cheers guys
Dosent come with the rods, you have to transfer the rods and selector box from the old mechanism across to the B&M.
Well worth it even with a few £ added to the price
The B&M kit from us is now £215 including postage.
It doesn't come with the rods. The price rise is just a natural annual price-amendment.
Got mine on yesterday
Does feel really strange at first, but for some reason (as much as I don't want to like it) I do like changing gear a lot
The problem I have with it is the amount of vibrations it makes the car produce, but part of the reason could be my car tbh.
Moving off from stopped, it makes a quiet whinning sound like a straigh-cut g/box.
The really ba****d annoying vibration is when putting me foot down ... when the turbo comes on full boost, the car violently vibrates and the natural reaction is to change gear fast.
If I can't get the vibrations to go, I might be tempted to put the old one back on as I use the car everyday and I'm pretty sure the vibrations would give me a headache
I had the same problem so stuck some rubber matting between the shifter and the underside of the car.
AHHHH !!!!
I've been looking for a post about that! I was sure someone stuck something between the shifter and the car.
Did it help ? And where did ya get the matting from ? Is it easy to put the matting in ? Do I have any more questions ?
I think the violent vibrations might be to do with the clutch slipping ... guess I do need a new one
I really had to do very little else with mine. I fitted it exactly as per the instructions. The only vibration I had was cured by bonding the lower console together with Stikaflex from behind. It is very good now and I am still very pleased with it, even though it is 4 years old.
I stripped it down and re-greased it with the last gearbox change 3 or 4 months ago and its like new again.
AHHHH !!!!
Ho Ho Ho
Did it help ?
Yes - Remove all the crap from car's tray areas - coins/sunglasses/CD
Old rubber car mat
Remove shifter and insert and refit shifter
LMK
See if the above help
All the best
Ho Ho Ho
Did it help ?
Old rubber car mat
LMK
All the best
There's nothing in the trays to vibrate, its definately the shifter hitting the chasis
Car mat ? is that it ? sounds too easy if ya ask me (I know you're not).
What about putting 2 layers of the rubber ? Or would that make things difficult ?
Does the rubber sit in between the 4 bolts on the shifter then is squished when the shifter is replaced ... making the gear stick slightly shorter than normal ?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
