Heated Front Screen Not Working?
Old Dec 4, 2006 | 06:31 AM
J9BBY's Avatar
J9BBY
Default Heated Front Screen Not Working?
Any common faults/places i should look for remedy?
Cheers,
Pete.
Old Dec 4, 2006 | 07:33 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it's quite straightforward as it's on a separate subloom direct to the battery.
there is a seperate fuse and relay somewhere under the dash on this subloom. could be either of those, or the switch or it could be not screwed on to the battery. or the screen itself may not be plugged on to that loom, or just buggered.
Old Dec 4, 2006 | 11:03 AM
J9BBY's Avatar
J9BBY
Great. Thanks Nick. I'll give said things a try!
Old Dec 4, 2006 | 04:07 PM
TurboShed's Avatar
TurboShed
Cossiemodo
If it's buggered doesn't it normally fail gradually?
Old Dec 4, 2006 | 05:02 PM
foreigneRS's Avatar
foreigneRS
Testing the future
TurboShed yes, you get some lines of the thin wire broken leaving streaks in the demisting/thawing
Old Dec 4, 2006 | 05:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Could be one of the timers or a fuse pete.
Old Dec 4, 2006 | 07:42 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
mines the same any one know where/ which relay it is
Old Dec 5, 2006 | 07:18 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the timer is part of the relay iirc - it's a black one, quite big. just trace the sublomm back from the connections to the windscreen to find it under the dash.
on my lhd, it was kind of behind the removable panel on the passenger side behind the abs ecu
Old Dec 6, 2006 | 04:13 AM
Default HFS
MY sapph lost the feed to the switch when igntion on so I just connected from rear one.
3i Jim
Nov 20, 2015 05:12 AM
track.focus'd
Aug 12, 2015 05:53 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
