need some help with the torque of the screw
hello this is one of my first questions for you guys. i'm from norway so you must exuse me for my bad english but i will try.
the question is this:
i bought me some topbolts for my engine. they have12.9 quality. i was wandering how much torque this screws is going to be mounted with?
thanx for any answer
Mr Haynes says,- tighten in 4 stages 1, 18 ftlbs 2, 40 ftlbs 3, further 90 degress 4, further 90 degrees.
Me, I add a stage 2+ and tighten them to 60 before 90deg and 90 deg cos
it's running a fair bit of boost and I don't like blowing head gaskest.
Originally Posted by tuszi
one more question. do i drag the bolts to this torque and thats it? no 90 degrees or so?
Also ensure that you coat the hole bolt including the washer with copper slip or simular.
Simon.
DavidK
Sep 27, 2015 02:55 PM
