Help ZT Turbo
hello mate, i have got a set of steel rods from america, and am told that they are for the blacktop engine, what pistons could i use to get them to work in the silvertop? regards dave
yeah i could use standard black top pistons but i want forged ones, cant i get these imported from the states?? also whats the best compression ratio for the job of a 250bhp+ ZT Turbo?
Originally Posted by davsmith64
well this engine i have is a mondeo 2ltr, so i imagine it is a silver top, so what pistons would be the best??
also is 10:5::1 too low comp??
10.5:1 is too high...you need about 8.2:1 and it will easily see 250hp
bassboy
any ideas where i can get a set of 8:2:1 comp pistons then? i am clueless, and i aint a clue how to order custom spec pistons..lol
which rods did you buy eagle or cosworth?
eagle rods mate
yeah, these aplications dont come with the rings do they? i need to buy the rings seperate??
whats your current spec and power read outs? im only looking for 300bhp regards dave
Originally Posted by bassboy
you wont be able to run alot of boost with 9:1
bassboy
bassboy
eagle rods mate
Dave.
bassboy
bassboy
calibra turbo pistoons do have a ratio of 9:1 ando produce a fair bit of power, these are a popular choice of piston by ZVH builders. but i have got steel rods and the pistons wont fit them, think i may be buying a set of custom made ones from diamond, and have already chose my managment (emerald).. will see how it goes.
The only real difference (if I recall correctly) between the 2 engines is a crank/rod geometry change with the better geometry being in the black top. Ideally you want the crank out of the black top too so you can take full advantage of the revised geometry.
bassboy
bassboy
also depends if the car is a top speed racer or a quick point to point car with minimal lag
bassboy
Originally Posted by Alex_86
turboboss
they have Compression: 9.0:1
isnt that to high? or is that ok? I am building a zvh my self and they was some cheep pistons
eagle rods mate
Dave.
yeah but does this piston kit come with rings?? part number - 185915
from www.nolimitmotorsport.com
YES they even state the part number for the rings thats where mine comes from with rings
e-mailed them regarding the rings and heres what i got
""They come with the pins, but the Ring set is separate. Price is $510 with rings. ""
heres what i sent
""hello, just been looking through the catalogue and found the following item number - 185915 piston set
does these come with the piston rings, wrist pin ect???
regards dave""
heres what i sent
regards dave""
heres what i sent
regards dave""
heres what i sent
regards dave""
just had a look part number fro the rings are jxcof4 3346-2 priced at $82 and pistons $427 price has gone up was $429 all in still cheap though!! when i ordered the pistons i did'nt ask for the rings i just assumed they came with the pistons must of been lucky.. but still only Ł283 for a set.
Originally Posted by 205T16
turboboss, what compression do you run? sorry to bring back an old topic !
what size decomp plate will i need to lower the compression from 9.0:1 to 8.2:1 or 8:1?
regards dave
regards dave
1.2mm cvh head 57cc so with those je pistons and eagle rods comp ratio = 8:4:1 with 1.2 de-comp plate 7:8:1
its not going to be a zvh???
its a full zetec head..??
