4x4 Cosworth Buying guide???
Old Dec 1, 2006 | 08:22 AM
darrendarko's Avatar
darrendarko
Default 4x4 Cosworth Buying guide???
Hi Folks.
Any general advice, do's & dont's etc.. on buying a 4x4 Sierra Cosworth would be appreciated. Im a capri freak at heart, but gonna be looking for a Cossie in the near future.
Thanks.
Darren
Old Dec 1, 2006 | 09:30 AM
Smoker's Avatar
Smoker
Default 4x4 cossy
if your looking to buy a 4x4 go for the later facelift model,revised dash,green top eng pref looking to buy standard or modified? standard go for low mileage,modified go for rebuilt eng saves you money later
Old Dec 1, 2006 | 09:44 AM
darrendarko
Hi. Thanks for the reply. Yeah will definitely be looking at a modded one.. have seen some super ones on ebay- upto about £5k. I was wondering if there's any specific things to look out for on these cars, funny noises, appearance of smoke, rust spots etc. Also, just briefly, whats the whole YB and green top/red top thing about?
Thanks again.
Darren
Old Dec 1, 2006 | 10:27 AM
Smoker's Avatar
Smoker
Default 4x4
a stage 3 saph would be ideal try and find 1 with a t34/t35 turbo,rs500 cooler,uprated shocks,brakes the more the better! rust usually can be found on the rear arches/tailgate/sparetyre well,also rule number 1 check the vin plates especially the 1 by the drivers seat,dont wanna buy a ringer! avoid cars without any history. yb is just an engine code red top was leaded eng, green top was unleaded the better 1 more stronger
Old Dec 2, 2006 | 12:02 PM
darrendarko
Thats a great help mate, thanks for that.
darren
Old Dec 2, 2006 | 12:54 PM
Daveesaunders's Avatar
Daveesaunders
Decembers Fast Ford has a buyers guide in it for this model
Old Dec 2, 2006 | 12:57 PM
darrendarko
Cheers Dave, I will pick up a copy of fast Ford!
Old Dec 2, 2006 | 05:10 PM
macker's Avatar
macker
Jay has got a mint one in the for sale section mate.
My old one. Car is a credit to its previous owners & had a rebuild a few years ago.
It is a very very nice un abused car.
Well worth a look mate
Old Dec 2, 2006 | 08:26 PM
Twellsie's Avatar
Twellsie
watch for the gear box, make sure that the gears easily engage when changing at high rpm (without a crunch). Sun roofs are also quite prone to leaking, not the end of the world but a bit of a pain in the arse.
Old Dec 3, 2006 | 02:32 PM
melzieann's Avatar
melzieann
when u go too look at 1 make sure the engine is stone cold before u start it, my advise is if engine warm walk away it may rattle when cold hence why the owner has had it runnin before u got there, check history the more the better.
Old Dec 5, 2006 | 10:24 AM
stonehavencossie's Avatar
stonehavencossie
Default Re: 4x4 Cosworth Buying guide???
Originally Posted by darrendarko
Hi Folks.
Thanks.
Darren
ive sent you an email to your hotmail of a .pdf buyers guide. you will need acrobat reader
As mentioned as well as solid body work the engine is the most important part of the car as it is the most expenisive to fix. A strong engine is a must or it will hit you in the pocket (i know ). Try and get one that has had a recent (reputable) rebuild.
Also, the 4x4 as standar is not that great performance wise. Stage 3 is perfect for this car. If buying a modded one make sure it has been done properly by a tuner. Stay away from a DIY conversion. Even if its running right the actual fuelling might be out.
Good luck
MARKYMARKONE
Aug 20, 2015 12:55 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
mattman1234
24
Aug 1, 2015 11:46 AM
Old ford
Jul 31, 2015 06:50 AM
