Fuse Box
My fuse box has a few melted terminals around relays, I have the whole loom out of the car at the moment. I want to replace the whole box and have been quoted £123.21 for the privilage are there any better alternitives to the ford spec??
Dominic
Dominic
Originally Posted by JamboRST
Originally Posted by SafeChav
What car mate?
You never know mate.
Well.......seeing as a RST fusebox isn't designed to be removed the norm thing to do is change the entire loom.
I doubt very much if you can get new fusebox boards and connectors from Ford now!
The parts are avaliable from germany,
Thankyou for your Enquiry.
The Fusebox Housing and Junction panel are no longer available from Ford.
I have managed to locate stock in Europe of these 2 items.
Escort RS Turbo (Series2)-Fusebox Housing-Fuse Junction Panel
Part Number: 1604605(QTY1)
You Pay: £17.26
Escort RS Turbo (Series2)-Fusebox Panel Assy-Fuse Junction
Part Number: 6150915(QTY1)
You Pay: £73.22
Escort RS Turbo (Series2)-Fusebox Wiring connector
Part Number: 6104295(QTY25)
Retail Price: .30p each
You Pay: .27peach
Part Number: 6135934(QTY4)
Retail Price: .77p each
You Pay: .70p each
All I want to know is, what are the alternitives??
You Pay: £17.26
You Pay: £73.22
You Pay: .27peach
You Pay: .70p each
Its not hard, it can just be time consuming as you have to remove the dash and all the boot trims etc.
I had a loom out of a car down the scrappy in about 2-2.5 hours, i removed the dash properly, but just ripped out all the boot trims.
Theres far worse jobs you can do on a MK4
I can't see the point of replacing the loom with another 15yr old loom.
Is it possible to buy part of the loom new? I want everything but an engine loom at the moment then after the engine is in replace the engine loom and mangement
As i said further up, these looms weren't designed in that way, they are one solid loom.
The 22 year old loom in my cabriolet is fine so i think a 7 year younger loom is going to be ok
As the saying goes, if it aint broke dont fix it!
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
