Low comp escos engine(SOLD)
For sale soon.
spec: low comp mahle pistons(7.2:1),arp bottom end bolts,balanced bottom end,wrc head bolts,grpA gasket,bd10 cams,isky springs,lightly ported head. Complete minus injectors(could come with greys) fuel rail ,TB and exhaust manifold.
Looking for £1700 no offers
could also come with 2wd sump and oil pump.
inlet #1
inlet #2
inlet #3
inlet #4
balanced pistons and bottom end
T35 turbo turbotechnics stage 3 cut back blades ect with a .55 housing, ran fine on my car with very little play and no smoke. £350 SOLD
P8 ecu with motorsports developmentswith air injector board and live mapped chip for above spec engine and turbo running greys. Offers.. (this mightnot be available for a couple of weeks, depending on new colins ecu)
inlet #1
inlet #2
inlet #3
inlet #4
Engine is now out the car and on my engine stand ,will get some pics up later this week.
Came out of my 50000mile escort due to spec change, was ran on greens then greys with a live map from msd, serviced every 6000miles loads of old paperwork for the engine and mag features with all the details.
sorry to those that pm'd me before but i manged to wipe my inbox
Should also have a set of greys forsale aswell.
Just got a 4x4 oil pump and pick up as i switched this onto my new engine , so this engine will now be available with the choice of 4x4 sump and pump or 2wd set up.
sorry rab, i put this post up ages ago and actualy forgot about it, just cleaned the engine up and fitted the 4x4 oil pick up and sump this morning so thought it would update it with some pics
ekjim
Aug 17, 2015 08:57 PM
