managment conversion
i want to start an engine rebuild and take on a cossie management conversion how hard is the conversion and what does it involve ?
GIVE JANO ODDKIDD A CALL MATE HES A REAL NICE BLOKE AND KNOWS HIS STUFF ABOUT THIS CONVERSION,
GIVE HIM A CALL ON 07050133596 OR CONTACT HIM VIA HIS WEB SITE WWW.ODDKIDDCREATIONS.CO.UK
HTH
HTH
i think 2k is fitted mate i have just had a diy kit of him and i have got to say he is a top bloke when it comes to fords mate he will be able to help you fella
JIM
JIM
Originally Posted by grsford
good call i will try but im sure it cost`s in the region of 2k
JIM
JIM
smitsturbo From when i was talking to jano about it when i went to to get the kit off of him it sounded easy enough to do but i have not started fitting my kit just yet as iam in middle of doing all the body work frist then when that is finished i will be fitting the management mate
jamie rst
looks like were going to be doing the same things only your starting first so you can warn me what not to do
can you give me a rough price for the kit and what you got or is it secret
grsford No mate there is no secret on the kit i have had but there are some different thing you can have on your kit like you can keep your dizzy car and still run the kit or you can go for a dizzy less which would be like a frst so you would have a module were the dizzy cap goes and there are some more thing can have or not have because there are thing like smaller fuel filter and the braket he has made so that you can fit it to your gearbox so you do not have fuel pipes going across you engine bay its just about how fare you would like to go with it mate so as for the price it best to give him a call and he will be able to give you a figure mate.
here is his number and web site on the site there is a full up to date list of parts and price's as well fella hope this will help you out mate
www.oddkiddcreations.co.uk
call jano on 07050133596
It wont be that hard. Not much harder than converting to FRST. Probably the 2 hardest bits will be fitting a CPS and cam phase sensor.
Indeed Jano does swear by cossie management im sure he will be able to help!
mk3ste
Oct 17, 2021 10:09 AM
deathrider666
Sep 28, 2015 06:12 PM
