please help :(
Old Nov 28, 2006 | 05:52 PM
Maxxeh's Avatar
Maxxeh
Default please help :(
rite ive changed fuel pump, starter motor and distributer. After doing all that it finally turns on. However, it is extremely lumpy. I have run out of ideas.
Please help. its f**kin pissing me off!
Old Nov 28, 2006 | 06:17 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Check the cap and rotor arm are in good order, and all leads are good.
if its still lumpy
Take the plugs out, give them a clean and let em dry first of all.
I remember you sayingyou changed the pump but it got worse, did you change it back for the old one?
Old Nov 28, 2006 | 06:19 PM
Maxxeh's Avatar
Maxxeh
Ive had a new cap and rotar arm and got new leads and plugs.
Ill try taking the plugs out.
ill also change it for the old pump and ill let u kno.
Old Nov 28, 2006 | 06:27 PM
NUTS RuS's Avatar
NUTS RuS
Whats lumpy ?
You mean its not running right ? Wont tick over ? wont drive ? Timing wrong ? Plug leads on wrong ? Running on 3 ?
Give us a clue at least
Old Nov 29, 2006 | 12:04 AM
Maxxeh's Avatar
Maxxeh
Its running very lumpy mate. Cant move the car, as it really sounds awful. plugs are done properly, I double checked.
Could it be the timing wrong as i changed the distibuter?
Old Nov 29, 2006 | 12:07 AM
smitsturbo's Avatar
smitsturbo
what about fueling? has that been checked mate?
Old Nov 29, 2006 | 12:19 AM
Maxxeh's Avatar
Maxxeh
I had the fueling done about a month ago when it was set up.
Old Nov 29, 2006 | 12:33 AM
smitsturbo's Avatar
smitsturbo
timing is maby out a fraction???
