mot ? will i fail if
Right i really have fluked this one lads
Went out to my car earlier , to try and solve this abs light problem , stripped surroun out and took out clocks as far as i could and turned ignition on to see what bulb were lighting up
Now abs lights came on for abut 5 secs then went off
then when i started engine the came on briefly then back off
Think ive sorted it but no idea how i did , never done anything , gave it a few tests there with everything back together and its fine now , they come on when turn ignition on then go back off soon after and the same if i start it , must be my lucky night
was going in there to rip out bulb too
Pulling the bulb out would have still resulted in a fail during a properly conducted MOT test anyhows as the ABS lamp has to follow the correct sequence as detailed in the testers blue vosa worksheet for that particular vehicle
SMILER258
Sep 28, 2015 09:04 AM
