s2 cossie disc conversion
Aug 31, 2004 | 11:10 AM
whats used on the fronts ?
2wd discs and 4x4 front callipers ?
Aug 31, 2004 | 11:21 AM
yeah 4x4 calipers but you can use either 2wd or 4x4 discs, 2wd are 283mm where as 4x4 ones are only 278mm
i've got the 4x4 ones on mine, only because i got them cheap
Aug 31, 2004 | 11:25 AM
4x4 discs Shouldnt fit properly summat to do with the mating face being different, and you can use S2 calipers with 2wd discs with a bracket kit.
2WD are 4 pots tho, although they have to be machined down a little to fit, surely this is worth it for the extra stopping power
Aug 31, 2004 | 11:27 AM
i had 2wd 4 pots on my S1, and they never worked right, i wouldnt bother for the hassle thats involved
Aug 31, 2004 | 11:42 AM
Quote:
Will that fit behind a standard S2 wheel then and how much better is the braking??
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
