4wd gear stick
Old Nov 27, 2006 | 09:22 AM
ricky's Avatar
ricky
Default 4wd gear stick
can a gear nob be change on a 4wd how does it come off
does it screw off or wat
Old Nov 27, 2006 | 09:23 AM
GARETH T's Avatar
GARETH T
it pulls off
Old Nov 27, 2006 | 09:24 AM
rstoughy's Avatar
rstoughy
as above ^^^^^^^ Pulls off M8,
stand with a leg either side of the tunnel and open the sunroof and just give it a good pull straight up. that should do the trick
Old Nov 27, 2006 | 09:58 AM
ricky's Avatar
ricky
paul
is this a wind up m8
Old Nov 27, 2006 | 10:24 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's true
or you can just cut the top off with a knife
but you wouldn't be able to use it again
mind you, if you tywist and pull it snaps the little locking plate and you need a new one anyway
covered plenty of times on both the escow and sierra forums
Old Nov 27, 2006 | 10:28 AM
rstoughy's Avatar
rstoughy
Originally Posted by ricky
Paul
fraid not, but it does the job
Old Nov 27, 2006 | 10:30 AM
R5FORD's Avatar
R5FORD
pain in the ass 2 get off
JjCoDeX75's Avatar
JjCoDeX75
If you want to reuse the nob, and this is for other reasons, (eg gearbox removal), the other way is to remove the knob and shaft complete.
Remnove the plastic surround panel, lift up the leather gaitor, and underneath you will see two pins. One stops it from going into reverse without pulling up on the thingy, and the other further down holds the stick on.
Ignore the longer one, that can stay there. Use a centre punch and hammer, and remove the pin, and then carefully (but with some effort) twist off the stick. Then you can refit afterwords in reverse.
Hope this helps!!
boeb
Jan 9, 2020 05:11 AM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
SMILER258
Sep 28, 2015 09:04 AM
