faster on half than full ?
Nov 26, 2006 | 09:56 PM
mates just bought a rs turbo chipped running 18 psi the thing is it pulls harder on half throttle than on full any ideas what it could be ??
Nov 26, 2006 | 11:35 PM
Standard Intercooler?
Could be that 18psi is causing the air temps to rise, resulting in ignition retard. Wouldn't be the first time I had heard of this.
Nov 27, 2006 | 12:26 AM
throttle position sensor fucked ?
my 306 used to accelerate quick and then when u slowly let off the throttle it would speed up, and it wasnt turbocharged therefore must have been ecu or tps ?
Nov 27, 2006 | 12:36 AM
no its got a grs intercooler piper cam and stage 3 hybrid turbo
could it just need a setup ??
Nov 27, 2006 | 09:52 AM
If it aint been setup for a while then it will be worth having it done just to makesure everything is as it should be
Nov 27, 2006 | 07:40 PM
KE won't hit full on boost enrichment if you don't use full throttle so it will feel faster as it runs lean.
Nov 28, 2006 | 01:32 AM
Quote:
Can you expand on that a little daz?
im aware the TPS triggers full load enrichment, just the latter bit im referring to
Mark_
14
Jan 16, 2016 05:27 PM
steve.rst
Oct 3, 2015 08:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
Carlbacciochi
Sep 26, 2015 04:23 PM
